App watch dog recover sshipsecpm dead
Thank you for all your valuable feedback. We are actively working on this issue and developing a new firmware version specifically for this case. As soon as the firmware is ready, we will provide an update in this thread. We appreciate your patience and cooperation.
This is it:
You need to create the following rules:
Then:
Do not have it enabled at first.
Move the rule to a positiion after the allow rule.
Then enable the rule.
This should resolve the issue for now.0 -
Please don´t use workaround for now, it may make more trouble in future :)
We will update this thread quite soon with better solution steps.0 -
We experience the same issues on USG FLEX 100 & USG FLEX 200.
Firmware 5.36(ABUI.1)C0, changed by 5.35(ABUH.0) but the problems are the same : Impossible to acces GUI Admin, VPN Disconnected.We wait a solution.
Same issues for us, with many USG210, USG310, Flex200, firmware up to date.
VPN IPSEC go down after a few minutes… many customers impacted
Hi, Same Issues for us. Differents Models impacted. Firmware Up to Date. VPN Disconnect / reconnect after maximum 900s
2 -
Same issue here on USG110, on the latest firmware. VPN connections drop after around 15 minutes.
The issue has fixed by firmware. You can download firmware by this thread.
Hello, I have a USG FLEX 200 on nebula cloud how do I update manually?
- 588 USG FLEX H Series
- 477 News and Release
ZCNE Certified
