ZLD4.73 & ZLD5.36 patch 2 Official Version Released to address Buffer Overflow Issues
Zyxel_Stanley
edited April 2024 in Security
Dear Community members.
We have been notified several VPN connection related issues and network interruptions reported to us currently. In response to this issue, we have expedited the development of firmware applicable to all models, which is intended to address and promptly rectify the situation.They are available for immediate downloads in below link
USG FLEX/ATP/VPN Series (Release date: May, 2023)
USG FLEX
ATP
VPN
USG FLEX 50
Download
ATP100
Download
VPN50
Download
USG FLEX 50W
Download
ATP100W
Download
VPN100
Download
USG FLEX 100
Download
ATP200
Download
VPN300
Download
USG FLEX 100W
Download
ATP500
Download
VPN1000
Download
USG FLEX 200
Download
ATP700
Download
USG FLEX 500
Download
ATP800
Download
USG FLEX 700
Download
USG/ZyWALL Series (Release date: May, 2023)
USG Series
ZyWALL Series
USG40
Download
ZyWALL110
Download
USG40W
Download
ZyWALL310
Download
USG60
Download
ZyWALL1100
Download
USG60W
Download
USG110
Download
USG210
Download
USG310
Download
USG1100
Download
USG1900
Download
USG2200
Download
«1345678
  • GruppoEmiliani
    GruppoEmiliani Posts: 1 image  Freshman Member
    Zyxel Certified Network Administrator - Switch First Comment
    Hello everyone,
    I can't reach the web console of the usg flex 100, how can I update the firmware? Do I necessarily have to reset it?
  • Mario
    Mario Posts: 111 image  Ally Member
    Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Seventh Anniversary
    Hi @GruppoEmiliani
    Please check the supportpage of Zyxel EMEA, there you find ann FAQ covering your issue:
    https://support.zyxel.eu/hc/en-us/articles/11616709217810
    good luck
    Mario
  • nielsscheldeman
    nielsscheldeman Posts: 96 image  Ally Member
    Hello, all out of a sudden 1 after another of our firewalls aren't reachable through console or do not have internetaccess, this in the past hour.
    However automatic firmware updating is disabled, is this something that has been pushed and now causes big problems?
  • BsalgadoEU
    BsalgadoEU Posts: 5 image  Zyxel Employee
    Hi @nielsscheldeman
    Please check the information and follow the guides indicated on our Zyxel EMEA Support Portal:
    https://support.zyxel.eu/hc/en-us/articles/11616709217810-Unstable-VPN-Connection-Webinterface-Login-Issues
    You might need to reboot your device to get access to stabilize it first and being able to access it. If you still have issues, please feel free to contact our Zyxel EMEA Support team on https://support.zyxel.eu
  • nielsscheldeman
    This of course wasn't my question, I do know of the hotfix. My question is: why is this happening on al our firewall's at the same time when automatic updating is disabled? We have 50 ZyXEL FLEX Firewalls(mostly 100/200 and couple of 50/500's) running, 34 USG40/60 and 6 ZyWALL 110!! Many of them with (L2TP over) IPSEC tunnels configured… This is dramatic if we have to update all 90 of them on site.
  • MarkoD
    MarkoD Posts: 70 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    edited May 2023
    We also have circa 3 USG40W and 3 USG60 deployed and half of them are affected by this incident. USG40W becomes totally unreachable after about 2 hours and USG60 is reachable, however it drops all VPN connections after a couple of minutes.
    PS: To mitigate the issue until we can update the FW on-site, it helped to limit WAN ports for VPN using Geo-IPs (in Policy Rules).
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @nielsscheldeman
    It shouldn't be force upgrade on your device, are all your on-cloud devices be upgraded automatically? Would you share your org information with us in private message and we'd like to learn more from it.
    We deeply apologized for certain inconvenience happened to you.
    Thank you
  • nielsscheldeman
    Will do that shortly. But now we have upgraded couple of the most urgent ones with site 2 site connections (14 devices have site 2 site, client to site think we have like 20 of those) to the firmware I downloaded above for FLEX 200 (V5.36(ABUI.1)ITS-23WK21-r109592 / 2023-05-23 18:54:50) which is V5.36 Patch 1.
    Now we receive a mail from ZyXEL which shows me this:
    Please don't tell me that Patch 1 is impacted as well??
  • MarkoD
    @nielsscheldeman The FW version you have applied (V5.36(ABUI.1)ITS-23WK21-r109592 / 2023-05-23 18:54:50) isn't "Patch 1", but a "Patch-1 Hotfix-23WK21" firmware which should be the same as Patch 2 (which is the official FW bundle).
  • XMFI
    XMFI Posts: 3 image  Freshman Member
    Hello
    I've got several IPSEC VPN with a center USG210 and the branches are on old USG20 series (7)
    Is there a fix or a method to mount the VPN since the hotfix.
    I've already installer the fix for the USG210 but the others usg20 are stuck and the VPN won't lift.
