i want NWA1123-ACv2 in standalone mode or manage mode
hoon
hoon Posts: 2
edited May 2024 in Wireless
I uploaded the firmware version to the latest version
6.10(ABEL.8)CO
Before I updated the version, I was in sa mode, but after the update, I stuck in cloud mode, so I couldn't set it up.
Connect to ssh and configure terminal
if enter : show hybrid-mode
Result : mode: cloud
if enter : hybrid-mode standalone
SSH will be terminated when I type
I think the router is restarting, but when I connected it, it's still in cloud mode
I will change this to sa mode like before
If possible, I want to change to manage mode
I want to connect to the usg60 device and manage it. I've searched a lot, but I can't do hybrid-mode managed
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,136  Zyxel Employee
    edited May 2023
    HI @hoon ,
    We encountered this issue at other models and had the technical solution for that. However, the NWA1123-ACv2 is an End of Life model (End of RMA& Tech support 2023-01-31), with the latest firmware version being 6.10(ABEL.8)CO, we recommend performing a factory reset to restore the AP to standalone mode. You should not encounter the issue as the managed mode being changed after upgrading the firmware anymore.
    Please be aware that the NWA1123-ACv2 is a Flexibility model and cannot be managed by a Controller.
  • hoon
    hoon Posts: 2
    If I connect wan, it connects to nebula, so I deleted the device from nebula, and I think it's solved
    Thank you for your answer.
