help USG20- vpn
baudetd
baudetd Posts: 43  Freshman Member
Hello
I have a problem with a UGS20-VPN router.
and I'm really pissed off...
following an update to 5.36, it reset itself,
I therefore wanted to import the config but this one does not want it, it runs in endless loops.
How can we downgrade?
thanks very much !!!!
«13
    PeterUK Posts: 3,887  Guru Member
    Reboot to the other slot firmware
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @baudetd ,
    Greeting Forum,
    Did you have serial console cable ? May I have remote session to check the issue today ?
    Please kindly provide teamviewer/anydesk if you are available. Thank you
  • WJS
    WJS Posts: 156  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    so device reboot itself endless loop ?
    If so, you should not be able to log in the GUI or CLI , you need to fix it it by console cable..
  • baudetd
    hello
    Here is what I did to fix the problem:
    the router had reset, I accessed the interface via the default ip address.
    I downgraded the firmware to 5.35.
    then I reinjected my config and it worked.
    However, I still have some issues. when I connect to the interface, the cpu quickly rises to 100% and from time to time during the day I no longer have access to the interface and I have small vpn connection problems (because for information, I have 2 vpn to mount on 2 other ugs20)
    then I have a "gateway timeout".
    as if overloaded
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,397  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @baudetd
    ZLD5.36 Patch 2 Firmware has released. This update includes fixes for vulnerabilities, ensuring enhanced protection for your device against potential security risks.
  • baudetd
    are you sure i didn't have problem like the previous version 5.36
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,337  Zyxel Employee
    Hello @baudetd
    Because V5.36P2 has CVE fixes for CVE-2023-33009 and CVE-2023-33010 and according to the symptom you mentioned "gateway timeout", we strongly suggest you update to our latest V5.36P2 firmware.
    You can follow below steps to update firmware:
    Step 1: Disconnect the WAN port connection and reboot your device.
    Step 2: Access the device's Web-GUI using the LAN port.
    Step 3: Update the firmware to our latest version, V5.36P2.
    Thanks.
  • baudetd
    this is my router ,
    for update
    with file for 1 running and 2 standby ?
  • Zyxel_James
    Zyxel_James Posts: 788  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @baudetd you may upgrade to both partitions. I strongly suggest you backup the configuration file
    Are you able to unplug from WAN? If not add a block rule for VPN services to Zywall and reboot then upgrade standby to V5.36P2
