Zyxel VPN100 login problems
Jape
Jape Posts: 3 image  Freshman Member
I have problem with login tried login webui throught lan and when i entered my credentials it says i need change password
But i can't change it says invalid username/password i think there is problem with format of old password
loginname is xxx@xxx.com and old password contains special chars like $&
change password dialog turns loginname xxx%40xxx.com ← can this be problem or is it password
Do i have right theory or is that something else?
If i am right tracks how i can proceed?
  • Zyxel_James
    Zyxel_James Posts: 840 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @Jape
    How about using a serial connection to connect to the firewall?
    You can follow the procedure below to bring the username/password back.
    1. Connect to the firewall via Console port
    2. Reboot the device
    3. Notice when "Press any key to enter debug mode within 3 seconds" appears, and enter in the debug mode
    4. type "atkz -b"
    5. type "atgo" to booting device again.
    6. Now the device will reset to system-default configuration and backup the old startup-config.conf to startup-config-back.conf
    7. Login to the device after boot up, and download startup-config-back.conf
    8. Open startup-config-back.conf and find the below content: username admin encrypted-password $4$encryptedpasswordencryptedpassword$ user-type admin
      In your case, the username could be "xxx%40xxx.com"9.
    9. Change it to username admin password yournewpassword user-type admin and save it
    10. Upgrade the firmware to 4.73P2 or 536P2
    11. Apply startup-config-back.conf to your device after upgrading
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482 image  Zyxel Employee
    May I know the current firmware version running on your firewall? If you're experiencing issues, it might be worth trying the latest firmware version to see if it resolves your problem.
  • Jape
    Version was 5.32 but how can i update without access to firewall?
    Can you confirm is there any tips get access firewall or need i reset it and configure from zero?
  • Zyxel_James
    Hello @Jape
    4. type "atkz -b"
  • Jape
    I don't have physical access to device so i will go hard way resetting and setuping routing again and after that upgrade firmware and setup settings from backup file. Anyway thanks for help
