scr 50 axe
I have a problem : the lan connection is not stable. Since this morning, I had twice a disconnection and had to turn off and on the SCR.
What can i do to have a stable connection.
The WIFI is working… but I have a number of PC's and printers connected.
Thanks and have a good evening
Yves
Hi @yves3550
Which firmware version is working on your SCR50? The latest version is 1.00 patch 2 firmware. You may have a try the latest version and check if it helps in your case.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
