Firmware upgrade
We tried to update the firmware of our USG 60, but we do not come higher then V4.65. We tried the update with the webgui and also over FTP Command and Cloud. After the update execution there is no error message. We could not find a log file anywhere.
We updateted from 4.65 to the next available version of V4.70
After the reboot is still the Firmware 4.65 activ.
Hi @Füwall ,
Please kindly follow this guide to upgrade the firmware
On the other hands, we will recommend upgrade to 4.73 patch2 due to security concern.
Thank you
backup config reboot the V4.70 and reset it then log in and upload config then try V4.73P2
Hi @Füwall ,
Thank you
Danke für die Ausführliche Anleitung
Die Firewall hat sich leider sofort aufgehängt, sobald ich in die Konsole ging. Ich habe ein HW-reset durchgeführt und alles neu eingerichtet. Das Upgrade ging dann sogleich auf 4.73.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 488 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
