ZLD4.73 & ZLD5.36 patch 2 Official Version Released to address Buffer Overflow Issues
Hi. Have same issue on ATP 800 and old 1100 devices.
In my situation help change preshared key on both devices.
"Helps only change Authentication method on both side. If it was certificate, than change on preshared key, Or vice versa."
I wrote in topic
@MarekSK EOL devices (3.30) are not affected.
@Boiler1976 yes, please upgrade to 4.73Patch which we already provide the downlink in this article.
@alexey This thread is referring to the urgent buffer issue, we will work on your case in your article thread.
Hi @nielsscheldeman,
In my case, I still have the same problem, even if the update is installed, my USG210 firewall keeps blocking the entire network, and I must be disconnecting it from the electricity because I can't access it and my network environment is down.
Buongiorno,
Ho problemi con USG20-VPN con la connessione VPN ho provato ad accedere via web al firewall e subito mi propone l'aggiornamento al firmware 5.36 però dopo aver avviato la procedura alla fine l'operazione non va mai a buon fine
Come posso risolvere?
I have the same issue I have FLEX 100 and I updated it to last version but I still have the connection problem it keeps blocking the entire network for example in 1 minute i got disconnected again and again
We updated our USG FLEX 100 to V5.36(ABUH.2) why we still have connection issues ?
I'm getting the 504 Gateway timeout on a USG 20VPN router that had the 5.36 Patch 2 applied last week. I suspect there's another vulnerability or the patch wasn't completely effective. I'll have to do more testing.
@electsystech I would like to follow up your case, I've contact you through private message, please check your inbox, thanks
Hi @Zyxel_James
Please contact me
We are getting the same reports, devices who get unresponsive and need a reboot. Also after 5.36 p2.
Regards,
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
