ZLD4.73 & ZLD5.36 patch 2 Official Version Released to address Buffer Overflow Issues
  • alexey
    alexey Posts: 193 image  Master Member
    First Comment Friend Collector Eighth Anniversary
    Hi. Have same issue on ATP 800 and old 1100 devices.
    In my situation help change preshared key on both devices.
    "Helps only change Authentication method on both side. If it was certificate, than change on preshared key, Or vice versa."
    I wrote in topic
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @MarekSK EOL devices (3.30) are not affected.
    @Boiler1976 yes, please upgrade to 4.73Patch which we already provide the downlink in this article.
    @alexey This thread is referring to the urgent buffer issue, we will work on your case in your article thread.
  • EdwinSantana70009
    EdwinSantana70009 Posts: 2 image  Freshman Member
    Hi @nielsscheldeman,
    In my case, I still have the same problem, even if the update is installed, my USG210 firewall keeps blocking the entire network, and I must be disconnecting it from the electricity because I can't access it and my network environment is down.
  • overlink
    overlink Posts: 1 image  Freshman Member
    Buongiorno,
    Ho problemi con USG20-VPN con la connessione VPN ho provato ad accedere via web al firewall e subito mi propone l'aggiornamento al firmware 5.36 però dopo aver avviato la procedura alla fine l'operazione non va mai a buon fine
    Come posso risolvere?
  • mtaghadosi
    mtaghadosi Posts: 2 image  Freshman Member
    I have the same issue I have FLEX 100 and I updated it to last version but I still have the connection problem it keeps blocking the entire network for example in 1 minute i got disconnected again and again
  • mtaghadosi
    We updated our USG FLEX 100 to V5.36(ABUH.2) why we still have connection issues ?
  • electsystech
    electsystech Posts: 60 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    I'm getting the 504 Gateway timeout on a USG 20VPN router that had the 5.36 Patch 2 applied last week. I suspect there's another vulnerability or the patch wasn't completely effective. I'll have to do more testing.
  • Zyxel_James
    @electsystech I would like to follow up your case, I've contact you through private message, please check your inbox, thanks
  • EdwinSantana70009
    Hi @Zyxel_James
    Please contact me
  • DavidDeLaet
    DavidDeLaet Posts: 3 image  Freshman Member
    We are getting the same reports, devices who get unresponsive and need a reboot. Also after 5.36 p2.
    Regards,
