USG1100 - intermittent issue accessing resources on the web
imaohw
imaohw Posts: 124  Ally Member
First Comment First Answer Friend Collector Seventh Anniversary
Occasionally some of the devices on my network stop being able to reach some resources on the web. This is especially noticeable with mobile devices when they leave the local network and return.
One example is backing up google photos from a mobile device. Sometimes the backup does not start and sits waiting to connect. Accessing other web resources seems to work for the same device. Rebooting the USG1100 fixes the issue for a while.
I have captured a diagnostic file when the issue is occurring and another diagnostic file immediately after rebooting the USG when the issue is not occurring.
The USG is running V4.73(AAPK.1). I was not having this issue until I upgraded from V4.70(AAPK.0) to V4.73(AAPK.1).
    PeterUK Posts: 3,862  Guru Member
    edited May 2023
    download V4.73(AAPK.2) Unplug USG from WAN and reboot then update
  • imaohw
    @PeterUK - I didn’t see a fix for my issue in the V4.73(AAPK.2) release notes.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @imaohw ,
    We still strongly recommend install the 4.74(AAPK.2) to patch buffer overflow issue.
    Please kindly check if the issue still after installed the firmware. Thank you
  • imaohw
    @Zyxel_Kevin - Will install the patch.
    Do you want to review the diagnostic files I captured?
  • Zyxel_Kevin
    Hi @imaohw
    Ok, Please send the diag-info file by private message.
    Thank you
