Verifying a configuration file without loading it
Hi @StefanZ
Currently, we don't have this tool, but when you apply the config failed you could navigate to the Monitor to see the possible reason or you could provide the config file to us for troubleshooting purposes via private message. Thanks.
With it loaded you can check all settings manually to correct the problem?
I don't know the problem tho. The config works, but it reset on me two times now when applying an update.
Also the FLEX200 is not where i am – when it resets the config on reboot again, I have to take a drive.
So I was wondering, if there is some sort of a "dry run" to have the unit parse a config, but not apply anything.
Hi @StefanZ
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
