help USG20- vpn
  • baudetd
    baudetd Posts: 44 image  Freshman Member
    I confirm, I did the update in 5.36.
    The router resets . Subsequently, loading the config does not work ....
  • baudetd
    I am already in 5.36 (abaq2).je talk about my startup-config file that I can not load
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,398 image  Zyxel Employee
    Hi @baudetd
    Please have a try rename your config file as others(without space)
  • baudetd
    edited May 2023
    hello, I'm putting a standby to the test since we need the internet ..
    so I went back to 5.35. and I reinjected the config file startup.config.conf, and it works.
    I no longer have time to test and rename the files..
    I would like to understand something:
    1 -why when I insert firmware 5.6, the router reset
    2 -what does standby and running firmware do? why should both be updated with the same file?
    3 -why can't we insert the config file on version 5.36 ?
    thanks  very much
    PeterUK Posts: 4,189 image  Guru Member
    Just apply your config to 5.36P2 with “Ignore errors and finish applying the configuration file”
    It is best to stagger the firmware slots when new firmware comes out so that you update the standby slot.
  • baudetd
    hello ,
    how to updgrade with “Ignore errors and finish applying the configuration file” ?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 959 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @baudetd ,
    DId you resolve the issue ?
    Please feel free to contact us if need further assistance.
    Thank you
  • baudetd
    edited May 2023
    no
    I tell you, every time I update, the router resets and I can't import my config
    and this is exactly what happens all day long
    the router works, then I lose the vpn, I lose the web interface on the other hand I do not lose internet ....
    I had to restart the router every 2 hours....
  • baudetd
    is it possible to download the 5.34 firmware or less ?
    You have to backup config reset to defaults update the standby slot then upload config file click on it and apply with that settings.
