Cisco commands equivalent
Hello!
I need to make the following settings on multiple GS2210 switches.
Kindly tell me if there is any possibility to implement and how.
- Set enable password
- Set encrypted password (secret)
- Following cisco commands equivalent(if any)
[no service tcp-small-servers], [no service udp-small-servers], [no service finger],
[no service pad], [no ip source-route], [no ip bootp server], [no ip domain-lookup]
[no ip http server], [no ip http secure-server], [no tftp-server]
[no ip redirects], [no ip unreachables ], [no ip directed-broadcast],
[no ip proxy-arp], [no ip mask-relay]
4. Login banner
Thank you!
You can check the XGS2210's CLI guide, I cannot find GS2210's CLI guide, to find the command you need. I think there have some similar commands.
https://download.zyxel.com/XGS2210-52HP/cli_reference_guide/XGS2210-52HP_V4.70_Ed2.pdf
By the way, the Zyxel switch does not have a login banner in my record.
Thank you for your response. I've downloaded the guide and I will try to follow it command by command. Hope I will find what I need.
- 244 Nebula Ideas
- 6.9K Security
- 804 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
