Zysh Daemeon Busy Error / not accessible via Web GUI
I get frequent error message "Zysh Daemon Busy" during access on USG310 via Web GUI.
Sometimes Web GUI gets irresponsive, then displaying "Wrong CLI command, device timeout or device logout".
Rebooted USG310 couple of times without change of behavior, current firmware installed.Current Version: V4.65(AAPJ.1)
Hi @oybek21
Thanks for reporting this case to us. It seems the ZySH daemon is busy on your USG310, so it appeared this warning message. Could you update the firmware to the latest V4.73P2 firmware? This firmware has some CVE fixes, so we strongly suggest you can update it. Once you update V.473P2, but still occur "Zysh Daemon Busy", please provide the remote Web-GUI to us for further checking. I will send a private message to you later. Thanks.
Hi @oybek21
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
