replacement for ZYXEL router version XMG3927-B50A
I live in the UK and at the moment I`m on a FTTC with TalkTalk. Im using a ZYXEL version XMG3927-B50A as my gateway modem/router this is connected to two (2) TP-Link Archer AX50 routers via cat cable these routers are all linked/setup in In access point (AP) mode.
Everything is working great, no problem all I want to know what is the replacement/new model for my XMG3927-B50A that I could replace it with if/when I need to (also would the saved backup_restore file work in new machine) The only thing I would not need is G.fast but would ike same or better specs than the XMG3927-B50A
Many Thanks
Best Answers
Hello @bigkenny
Maybe NBG7510 would be a good replacement for you with your FTTC connection...
I don't think that you can restore the backup file as is.
Kind regards Tony
Hello @bigkenny
You're welcome, but I think that I made a mistake.
NBG7510 doesn't support VDSL, so it would not be a replacement for you if you need that with your FTTC connection.
Maybe DX3301-T0 would be good for you, as it definitely has VDSL, see https://service-provider.zyxel.com/emea/en/products/dsl-cpe/vdsl/dx3301dx3300ex3301ex3300-t0-series
Amazon.co.uk retail it.
Apologies for my mistake.
Tony
Ok many thanks for the update. I was having a look round and managed to get a XMG3927-B50A going cheap so going to get that and get it all setup with my config files and up date the firmware to same as mine. Make sure it all works and then pack it all away so if my original packs up, I can swap it all over with no bother as connected up to loads of TVs (an NAS) and linked to 2 other routers in AP mode, so would be a right pain to set a new one up from scratch. But will keep your info incase need to get it. thanks
Hello @bigkenny
Kind regards Tony
ok thanks its incase need replacement incase mine goes so Im ready
Hello @bigkenny
Tony
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
