I have to upgrade firmware, best practice
Not 100% sure, but there could be a chance your settings can become mangled. If it is a trivial procedure to make notes of your current settings and add them back manually after upgrading, then it should be safe to upgrade by resetting your device first, then upgrade, then rebooting and adding your settings manually.
If your existing settings are complex and you would want to keep them as intact as possible, you probably want to upgrade via intermediary versions, just to be on the safe side (I don't remember which firmware versions are known to be hard limits for keeping your settings).
Thanks i'll try.
@RikHead : Please also read the PDF manual present in every firmware zip-file download.
The manual (filename is the same as the firmware version) contains a "READ ME FIRST" section, telling you which minimum version you need before upgrading to the newest one. From reading the USG310 files, I found that 4.65 r1 is needed before upgrading to 4.73, but I have not had time to check USG110 yet. Hope you have been successful upgrading your device.
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 305 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
