Not overriding the local device password via a Nebula one by default
HI @k1s ,
Please tell us after enabling Zyxel support by going to Help (On the top right) > Support Request > Zyxel support access. We'll tell you once there is any update.
Zyxel_Judy
It is indeed enabled, and does indeed still behave that way
Hi @k1s ,
We confirm the issues as error message and no WAN status, Cellular info happen in your site. We'll check and tell you if there is any update. Please keep the enable Zyxel support.
Zyxel_Judy
Hi @k1s ,
For further investigation, we hope to have a remote session to check the connection between your NR7101 and Nebula. Please take a look at your Community inbox.
Thank you!
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 517 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.4K FAQ
- 97 Security Highlight
