Apple, Airplay 2 configuration help
tesagig
tesagig Posts: 60 image  Ally Member
Is there an article on how to configure the USG for apple/Airplay 2 services?
Whcih ports etc.
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @tesagig
    It's no need to set up anything if your AirPlay device and the host are in the same LAN subnet. (Because your rule
    LAN_to_Device allows all ports between devices and the firewall)
  • StefanZ
    StefanZ Posts: 202 image  Master Member
    First Comment First Answer Friend Collector Second Anniversary
    I would start with:
    Type
    Protocol
    Port
    UDP
    mDNS
    5353
    UDP
    Airplay
    7200 – 17210
    TCP
    Airplay
    5000, 7000, 7100, 50000, 7200 – 17210
    Allow that from ALL to ZyWall and vice versa and see what happens.
  • tesagig
    edited June 2023
    much appreciated!
    Just to clarify, I don't need to open ports to go outside (LAN to WAN). To make airplay work I only need internal traffic open? I do have already LAN1 to ZyWall fully open (any)
  • Zyxel_James
    @tesagig May I know your airplay topology? do you want streaming airplay cross VLANs? we currently do not support this scenario, thanks
  • tesagig
    edited June 2023
    no, just regular on local LAN
    BTW. In general. what is the logic for opening ports between Zywall and LAN? If I don't have any rule for Zywall to LAN do I block something?
  • tesagig
    Based on my other thread: can I simply accomplish this by flipping on "app patrol - airpaly"?
  • Zyxel_James
    @tesagig
  • tesagig
    thanks. airplay is working. Turns out there is a defect in the Bluesound PulseFlex speaker
  • ths
    ths Posts: 2
    I'm currently looking for a new solution for my home and had pretty much already decided to buy an AXE5400 with an XMG1915-10EP switch. But then I read about this Airplay limitation. I hear a lot of music but want to seperate all these sometimes pretty old and thus insecure speakers in an IoT VLAN so allowing Airplay and Spotify Connect between VLANs would be a must for me. May I ask if this feature been added in the meantime or is it on the roadmap for the very near future?
    Thanks!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,241 image  Zyxel Employee
    Hi @ths,
    Thanks for asking. Could you share your topology and the purpose you want to set VLAN in your home?
    Zyxel Melen
