I have to upgrade firmware, best practice
RikHead
RikHead Posts: 5 image  Freshman Member
Hi to everyobdy,
I have a UGS110 with firmware version 4.31, I need to update it to 4.73 due to the latest zyxell vulnerability notice.
Can I do it from 4.31 to 4.73 or do I need the versions in between first?
Thanks for any help.
  • smb_corp_user
    smb_corp_user Posts: 172 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Not 100% sure, but there could be a chance your settings can become mangled. If it is a trivial procedure to make notes of your current settings and add them back manually after upgrading, then it should be safe to upgrade by resetting your device first, then upgrade, then rebooting and adding your settings manually.
    If your existing settings are complex and you would want to keep them as intact as possible, you probably want to upgrade via intermediary versions, just to be on the safe side (I don't remember which firmware versions are known to be hard limits for keeping your settings).
  • smb_corp_user
  • RikHead
    Thanks i'll try.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @RikHead ,
    Greeting Forum, Please feel free to contact me if you have upgrade issue.
    Thank you
  • smb_corp_user
    @RikHead : Please also read the PDF manual present in every firmware zip-file download.
    The manual (filename is the same as the firmware version) contains a "READ ME FIRST" section, telling you which minimum version you need before upgrading to the newest one. From reading the USG310 files, I found that 4.65 r1 is needed before upgrading to 4.73, but I have not had time to check USG110 yet. Hope you have been successful upgrading your device.
