USG310 Won't Shut Down Through Web UI
I tried 2 times. This is what happens:
- Click the Shutdown button
- The SYS LED starts blinking and clients are disconnected from the Internet
- After about 5 to 6 minutes the SYS LED is solid again and the clients sre again able to connect to the Internet
In the end, the Shutdown process ends up being a Reboot process.
In the past, the Shutdown button would cause the SYS LED to blink for a few minutes while services were being closed. The SYS LED would then go dark, which I understood to be the signal that it's safe to press the physical power button in the back of the unit to OFF position.
I wasn't brave enough to go after the power button without first using the UI Shutdown button. I haven't ried CLI either.
The firmware is the latest version (4.73(AAPJ.2))
Any ideas?
Sorry for the late answer. I ended up taking the courage to turn the switch off. It came back. All is good.
Thank you.
Hi @DeeZed ,
Greeting Forum, Did you have console cable to check the output message ?
I don't have problem with latest version, please kindly provde diag-info and webgui access if you're available.Thanks
Thank you.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
