XMG3927-B50A firmware version
JConus
JConus image  Freshman Member
edited September 2021 in Smart Home Product
My Zyxel XMG3927-B50A is currently running with its stock firmware V5.13(ABQO.0)D0. I have noticed that a new firmware is now available as V5.17(ABMT.5)C0.
Will this firmware work for my device despite the different strings ((ABQO.0)D0 vs. (ABMT.5)C0) ?
-Joel
  • 3ll3
    3ll3 image  Freshman Member
    First Answer
    edited November 2021 Answer ✓
    Hey Joel,
    I update my firmware come from Swisscom (Switzerland) to the factory one this weekend because I needed to use mPro Mesh solutions from Zyxel.
    Base firmware branded : V5.13(ABQO.0)D0.
    Updated firmware : V5.17(ABMT.5)C0.
    Please watch this video to help you : https://youtu.be/vHDUjFk9u1M
    STEP 1 : Use Terminal (MacOs) or PuTTY
    ssh (ip router) -l (username)
    My exemple with Terminal : ssh 192.168.1.1 -l admin
    STEP 2 : Follow these commands when connected
    zycli
    zycli modelcheck
    zycli modelcheck show (Result : "ret:0")
    zycli modelcheck off
    zycli modelcheck show (Result : "ret:-17")
    zycli fwidcheck show (Result : "ret:0")
    zycli fwidcheck off
    zycli fwidcheck show (Result : "ret:-17")
    exit
    STEP 3 : Update your firmware with the web interface
    Enjoy :)
  • SEJ
    SEJ image  Ally Member
    (ABQO.0)D0 and (ABMT.5)C0 are different firmware versions for XMG3927-B50A.
    It can't be loaded with different firmware versions.
  • 3ll3
    First Answer
    Hey Joel,
    zycli
    zycli modelcheck
    zycli fwidcheck off
    exit
    Enjoy :)
  • bigkenny
    bigkenny image  Freshman Member
    Im trying to do this on a locked down KCOM isp router ZYXEL version XMG3927-B50A but when I get to putty its either freezing or times out.
    When I try to do it on my own ZYXEL XMG3927-B50A it works any idea as want to update and change the locked down firmware on the KCOM modem
  • JConus
    It looks like your SSH port is closed. Can you check in the web UI under "Maintenance → Remote management"?
  • bigkenny
    well had a look only HTTP and HTTPS open nothing else in. On my own other (same model modem/router) it has loads of stuff in SSH being one of them.
    I tried making a non admin account but stil the same……………its locked down to the isp config
  • JConus
    edited June 2023
    If your version is below V5.15(ABMT.5)C0, you should be able to use this: https://th0mas.nl/2020/03/26/getting-root-on-a-zyxel-vmg8825-t50-router/
    Obviously, don't do this unless you actually own the device.
    Good luck
  • bigkenny
    yes I have the modem still, but it looks a nightmare (after reading all that link) I`ve managed to buy another 2nd hand (same model) this one IS unlocked and even has the Firmware installed that I want (so all ok) I`m trying to get my money back for this locked unit as was it sold as locked and I was not told this.
    But thanks for the info maybe one day when bored and is raining outside I might (if still stuck with it ;-) give this ago whats on your link.
    Many thanks
  • bigkenny
    I got an other spare/second hand XMG3927-B50A yesterday it had the same firmware as mine but I flashed it again and it worked ok so on v5.17 (ABMT.6)C0 same as mine then update/copied over the same setting seems to work OK. I will test it out live when kids in school Monday but looks ok and a good back up to have incase mine packs in
  • bigkenny
    connected it all up this 2nd hand XMG3927-B50A and works a treat, good 2nd hand buy that works like my original :-)
