NWA50AX blocks a station
in my house I have many Zyxel APs (some NWA1123ACV2, some NWA1123ACV3 and an NWA50AX), I have an issue with the NWA50AX, particularly with a Samsung smart TV that is blocked by the AP about one time a day. The TV stops connecting to the AP and I have to turn the AP radio OFF then ON.
The AP is configured with 3 SSID on both 2,4Ghz and 5Ghz frequencies, the firmware is the latest V6.29(ABYW.1).
This is the repeated message I see in the log:
Station: a0:d7:f3:42:6d:36 blocked by Legacy STA Rejection on Channel: 40, SSID: Famiglia, 2.4GHz, Signal: -70dBm, Download/Upload: 0/0 Bytes, reason 27, Interface: wlan-2-2 | |
It's weird that I see Channel 40 on the 2,4Ghz band! I think that it could be an issue of TV but it is updated to the latest firmware too… but I cannot understand what it happens because all reasons I find are all "reserved" in the reasons code list.
Please help, thank you!
Alessandro
Hello Alessandro,
The log indicates that the station is blocked by Legacy STA Rejection. This could be due to the 'Allow 802.11n/ac/ax stations only' function being enabled for the SSID Famiglia.
You can check this by navigating to Configuration > Object > AP Profile > Radio on device's Web GUI. Choose the Radio profiles that are applied to your SSID, then click on Show Advanced Settings. Ensure that ‘Allow 802.11n/ac/ax stations only’ is disabled.
Furthermore, we suggest configuring a new SSID for IoT devices by following these steps:
- Configure a new SSID (Example: Zyxel_24G) with WPA2 personal security.
- Disable 802.11k/v Assisted Roaming
- Enable this SSID on Radio 2.4GHz only
If you continue to encounter the issue, please let us know.
Nami
Hello Alessandro,
Nami
Hi Nami,
First of all, thank you for your answer.
SSID Famiglia was already made for IoT devices and just configured as you said (v/k roaming disabled and 802.11 n/ax only disabled).
The only thing I just changed now in my configuration is to remove this SSID from 5Ghz radio.
I'll see what it will happen and then let you know about.
Have a good day
Alessandro
After three days since I pulled away the SSID from the 5Ghz radio and did reset the network options on TV, it seems to work good.
I noticed that TV had memorized the network as a 5Ghz network and I guess that that's the reason why it tried to connect to the channel 40 on the 2.4Ghz network… maybe a bug of Samsung's software?
Anyways, thank you for your support!
Have a good day
Alessandro
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 652 USG FLEX H Series
- 358 Security Ideas
- 86 Switch Ideas
- 55 Wireless Ideas
- 7.1K Consumer Product
- 303 Service & License
- 496 News and Release
- 94 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
