Unmanaged Switch MG105 - ping ok, internet ko
And now you can TCP to me suggests a PC/Mac problem or you can run Wireshark
or
tcping64 1.1.1.1 80
tcping64 8.8.8.8 443
Hi @Zotme,
You can also open some websites when you run Wireshark. This is used to capture the traffic to clarify the problem.
Also, could you try
ping 168.95.1.1andping 168.95.1.1 -l 1500when the client is connecting with issue MG-105? Since the previous result, I want to verify if the switch can forward 1514-byte packets.Zyxel Melen0 -
Maybe your NIC is set with jumbo packet bigger then 1514?
MG-105 NO ok
tcping64 1.1.1.1 80
Probing 1.1.1.1:80/tcp - Port is open - time=10.134ms
Probing 1.1.1.1:80/tcp - Port is open - time=10.277ms
Probing 1.1.1.1:80/tcp - Port is open - time=10.261ms
Probing 1.1.1.1:80/tcp - Port is open - time=10.179msPing statistics for 1.1.1.1:80
4 probes sent.
4 successful, 0 failed. (0.00% fail)
Approximate trip times in milli-seconds:
Minimum = 10.134ms, Maximum = 10.277ms, Average = 10.213ms**
Probing 8.8.8.8:443/tcp - Port is open - time=9.767ms
Probing 8.8.8.8:443/tcp - Port is open - time=10.103ms
Probing 8.8.8.8:443/tcp - Port is open - time=9.858ms
Probing 8.8.8.8:443/tcp - Port is open - time=9.992msPing statistics for 8.8.8.8:443
4 probes sent.
Minimum = 9.767ms, Maximum = 10.103ms, Average = 9.930ms**
ping 168.95.1.1
Esecuzione di Ping 168.95.1.1 con 32 byte di dati:
Risposta da 168.95.1.1: byte=32 durata=285ms TTL=53
Risposta da 168.95.1.1: byte=32 durata=285ms TTL=53Statistiche Ping per 168.95.1.1:
Pacchetti: Trasmessi = 4, Ricevuti = 4,
Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 285ms, Massimo = 285ms, Medio = 285ms**
Esecuzione di Ping 168.95.1.1 con 1500 byte di dati:
Richiesta scaduta.
Richiesta scaduta.
Richiesta scaduta.
Richiesta scaduta.Statistiche Ping per 168.95.1.1:
Pacchetti: Trasmessi = 4, Ricevuti = 0,
Persi = 4 (100% persi),MG-105 OK
Risposta da 168.95.1.1: byte=1500 durata=285ms TTL=53
Risposta da 168.95.1.1: byte=1500 durata=286ms TTL=53
Risposta da 168.95.1.1: byte=1500 durata=285ms TTL=53Statistiche Ping per 168.95.1.1:
Minimo = 285ms, Massimo = 286ms, Medio = 285msI don't know how to use Wireshark, sorry.
So what happens if you swap switches?
What…. as I said "I've two switch MG-105, in the same configuration router-pc-cables, one switch works the other no…".
Yes nothing makes sense as to why one works and the other does not so swap them over to see what happens.
- 603 USG FLEX H Series
- 480 News and Release
