EMG3425-Q10A..why has it been erased from existence? I am looking for firmware.
It seems this router has been wiped out, other than from the forums, from Zyxel's existence and i was wondering did "anyone" locate a backup site for firmware?
Hello @Kilroy5150
Welcome to the forum.
According to https://static.us.zyxel.com/pdf/2021/EOL-and-Warranty_Jan21_2021.pdf , EMG3425-Q10A went end of end of life by Zyxel in June 2020.
But the following thread might help:
It has 100AAYJ.18C0 linked to it.
Kind regards,
Tony
My current version is "V1.00(AAYJ.16)C1". Is it possible that the 'c1' version is causing the partial instabilities i am having with my connections and the slow response of the router at times? I've noticed, over my 53 years in all this, that there are times when 'newer' firmware can do more harm than good. Should i downgrade to 'c0' version and, if yes, what is the link?
Hello @Kilroy5150
Unfortunately, I haven't found any sort of archive, except what fellow user LeMishoK has tried to put together attached to the post I linked above.
I haven't seen any release notes being found though.
You might want to go to 100AAYJ.18C0 as the latest available…but I don't what the changes are from what you already have.
Kind regards,
Tony
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
