How to use LAN static IPs with SCR50AXE
GiuseppeR
GiuseppeR Posts: 437  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
I have a doubt about how to set LAN static IPs on the security router SCR50AXE
With other Zyxel firewalls I go to the section Site-wide - Configure - Security router - Interface and there I can set IPs inside its section "LAN Interface"
It is very strange to have this limitation on this hardware.
Why?
How can I solve that?
Thanks in advance
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,371  Zyxel Employee
    edited June 2023 Answer ✓
    Hi @GiuseppeR
    Here are the steps to set up static IP for the devices
    1.Go to the section Site-wide - Clients
    2. Select "Client list"
    3. Choose the category as "Secuity router clients"
    4. Select a client which is connected to SCR device and click "Policy" and select "Reserve IP"
    Or you can click Add Client to set up the static IP address
    1. Go to the section Site-wide - Clients
    3. Choose the category "Security router clients"
    4. Click "ADD client"
    5. Select the policy as "Reserve IP"
    You can set up static IPs for the devices on this page.
  • Zyxel_Jerry
    Hi @GiuseppeR
  • GiuseppeR
    @Zyxel_Jerry
    Thanks a lot, have a nice day
Nebula Tips & Tricks
