How to use LAN static IPs with SCR50AXE
I have a doubt about how to set LAN static IPs on the security router SCR50AXE
With other Zyxel firewalls I go to the section Site-wide - Configure - Security router - Interface and there I can set IPs inside its section "LAN Interface"
It is very strange to have this limitation on this hardware.
Why?
How can I solve that?
Thanks in advance
Hi @GiuseppeR
Here are the steps to set up static IP for the devices
1.Go to the section Site-wide - Clients
2. Select "Client list"
3. Choose the category as "Secuity router clients"
4. Select a client which is connected to SCR device and click "Policy" and select "Reserve IP"
Or you can click Add Client to set up the static IP address
1. Go to the section Site-wide - Clients
3. Choose the category "Security router clients"
4. Click "ADD client"
5. Select the policy as "Reserve IP"
You can set up static IPs for the devices on this page.0
Hi @GiuseppeR
You can set up static IPs for the devices on this page.0 -
Thanks a lot, have a nice day
- 588 USG FLEX H Series
- 477 News and Release
