Limit bandwidth USG 210
bad cable? NIC limited to 100Mb?
NIC on Zywall is set 1000 FULL DUPLEX, I don't verified switch port, but I don't think.
I will try with another cable
PeterUK sorry, but could be a problem of configuration? There is some setting that can limit the bandwidth?
Thank you
unless you have set interface rate limiting it should be able to go faster then 100Mb
@lunamic How about changing the port configuration from 1000 Full Duplex to Auto Negotiate?
and it seems there is a switch involved in the network, could you provide your test topology?Moreover, please check if there is a BWM rule or interface egress/ingress bandwidth settings
Hi James, I changed port configuration. effectively there is a switch that could to be the problem. I have to check. In the bwm I added a policy as you can see from the screenshot, but also without this was the same
The egress and ingress bandwidth are set to 1048576 Kbps.
Thank you
Sounds a bit difficult to troubleshoot, but would you be able to cross test the connection using other equipment, i.e. device supplied by the ISP as the only uncertain part in this connection test?
If you have tested all available settings on the ports and interfaces, maybe there is something incompatible in the combination of hardware (unless your connection used to work just fine).
- 441 Beta Program
- 210 Nebula Ideas
- 536 USG FLEX H Series
- 339 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
