WAN to LAN only from specified Range
valbuz99
valbuz99 Posts: 4 image  Freshman Member
hi
on one location there isn't it possible to get a vpn. so i want to selective the allowed ip's for the access to my lan inside.
on my zywall USG50 i'm define a object (range) for that. but when i want to make the nat rule, there is no choice to select this object.
what im doing wrong here?
is there a FAQ or else?
thanks a lot
pat
    PeterUK Posts: 4,427 image  Guru Member
    edited June 2023 Answer ✓
    You mean source IP range by NAT rule? I think the USG50 is too old to do that newer models can
    But what you can do is a policy control rule from WAN to LAN with source IP range
  • valbuz99
    hi Peter.
    thanks for answer.
    ok, thats possible ;-)
    i try with the rule.
    thanks so much!
    pat
