PLA5456 connection problem
I have previously had them working but recently one has been unplugged for several months.
My computer is a Mac and for the purpose of initially linking them, I have them on the same powerstrip.
#1 PLA has an active ethernet cable plugged in and the router 'sees' it. Its power and ethernet LEDs are a steady green.
#2 PLA is plugged in and the power LED is steady green.
When I depress the RESET/ENCRYPT button on #1 for about 2sec followed by depressing the RESET/ENCRYPT button on #2 for 2sec, the HomePlug LED on both blink for about 30sec, then both turn off. #1 still registers steady power and ethernet green LEDs, but #2 only has a flashing power LED - probably indicating it's in Standby Mode.
What am I doing wrong?
Ok, I did a simple connection without pressing the encrypt button and it works.
Thanks for the help, (and I should have tried this first).
If both devices are in the same pack. As I remember the PLA5456 does not need to pair to the other device after reset, they'll pair to each other.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
