WAX650S with poe12-60w and still limited power
edvhoerstelde
Is it possible to do it wrong? The WAX650S runs on limited power?!?
I had to force the full power mode for the AP.
Power Setting
Force overwrite the power mode to full power.
Note:
Only enable this when you are using a passive PoE injector which is not IEEE 802.3at/bt compliant. Abnormal reboots will happen in case of insufficient power wattage.0
Power Setting
Note:
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
