voip on a ugs20vpn router
baudetd
baudetd Posts: 44 image  Freshman Member
hello
since last update 5.36 of UGS20 vpn router
I have VoIP problems
is this a known bug?
thanks
  • DeanH
    DeanH Posts: 51 image  Ally Member
    Just to clarify, are you using a USG20-VPN or a USG20W-VPN model? As of firmware version 5.20 this changed to USG FLEX 50 or USG FLEX 50W, respectively.
  • baudetd
    it is the
    USG FLEX 50 (USG20-VPN) model
  • DeanH
    Ok. I don't have any of those, but if it was the USG FLEX 50W (USG20W-VPN), we have a bunch (approximately 100 or so) in the field and they are working fine for our VoIP services after upgrading.
  • baudetd
    I have a voip voice problem, the voice does not pass from outside to inside
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Agree , It would be better if you have capture files
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,590 image  Zyxel Employee
    Hi @baudetd ,
    kindly share some more information about VoIP issue.
    e.g. register fail from wan, or register ok, but fail on make phone call, or one way voice, etc.
