Firewall settings clone
DenizYildiz
DenizYildiz Posts: 5 image  Freshman Member
Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 1 - WLAN First Comment Friend Collector
We're going to set up a large amount of shops with a default device config: 1 USG FLEX100W, 1 GS1920-24HPv2 and 1NWA90AX.
It is easy to configure switch and ap settings with templates, but i can't seem to find the setting to do the same with the firewall.
I simply want to clone all of the firewall settings to each site from (for example) a template. What would be my best option here?
Thanks and let me know if you need more details.
  • Zyxel_Cooldia
    Hi @DenizYildiz ,
    You can just clone settings from existing site when you create a new site.
    Attached screenshot for your reference.
  • DenizYildiz
    Thanks for your reply.
    I've tried that but it won't copy the firewall settings, or am i missing something?
    Do i need to add the same model firewall before i copy the settings, or maybe afterwards?
Nebula Tips & Tricks
