Feature request Wan speed test and app wifi test
It would be helpful if we has some speed testing tools built into the gateways. Occasionally I use Firewalla routers and they have the ability to perform WAN speed tests on demand and periodically with a graph display. They also allow you to do wifi speed tests from the app through an access point to the router so it's strictly the LAN network being tested which I love being able to do. Great for testing a specific AP through its cable to the router and nothing else.
Hello @vining
Thanks for your feedback. Currently, we don't have a plan for this feature, I will move this to ideation, thanks.
- 603 USG FLEX H Series
- 481 News and Release
