Firewall settings clone
We're going to set up a large amount of shops with a default device config: 1 USG FLEX100W, 1 GS1920-24HPv2 and 1NWA90AX.
It is easy to configure switch and ap settings with templates, but i can't seem to find the setting to do the same with the firewall.
I simply want to clone all of the firewall settings to each site from (for example) a template. What would be my best option here?
Thanks and let me know if you need more details.
Hi @DenizYildiz ,
You can just clone settings from existing site when you create a new site.
Attached screenshot for your reference.
Thanks for your reply.
I've tried that but it won't copy the firewall settings, or am i missing something?
Do i need to add the same model firewall before i copy the settings, or maybe afterwards?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
