Clients connecting to APs through a Zyxel GS1920 not reaching the RADIUS server
I replaced my Cisco switch with a Zyxel GS1920. Figured out all the VLANs and internet is working great. The problem I am running into I have a Network Policy Server (NPS) to authenticate users to an employee network. This worked fine in the old Cisco switch, but now it stopped working. I added the IP to the NPS server and selected RADIUS standard. The RADIUS IP and port are added to AAA.
The guest network works fine, no authentication is required. It is only when I need to authenticate. Any ideas about what I could be missing?
Hi @Patrick_M,
Below is my NPS constraints setting for you to reference:
And you can also check the switch MAC table to check if the client passes authenticate or not. In your scenario, the client's MAC address will be listed in VLAN 10 once it passes authenticate.
Zyxel Melen0
Hi @Patrick_M,
Please reference this FAQ first to make sure the configuration is correctly set up.
Zyxel Melen0 -
So I followed the instructions. When I went to put the port authentication (802.1x) on, I added it to the switches. That broke my switches communicating with the server. Added the port authentication (802.1x) to the APs and it disconnected them.
Do I need to add MAC authentication and Guest VLAN like the document says? I am only looking to use the 802.1x.
I wondered if I needed to activate the port the server is on for Port Authentication 802.1x.
Hi @Patrick_M,
You don't need to add MAC authentication since you only use 802.1xl. But you mentioned you have the guest network, so I recommend adding guest VLAN configuration. And you don't need to activate the server port for authentication since this port is a trusted port.
By the way, could you provide some additional information about the scenario of your network? It would be helpful to know if there are both WiFi clients and clients connected via Ethernet cables, as well as whether all clients need to go through an authentication process.
Zyxel Melen0 -
The switch is in the server room so an overview of the devices connected.
- Firewall connected to port 1 with all the VLANs
- 2 servers on VLAN 10, connected through an ethernet cable on ports 2 and 3
- 4 access points connected to all VLANs on ports 21 to 24
- Several PCs for employees to use on VLAN 10
- 1 remote switch on port 45
I will be adding a lot of devices in the future.
I have Extreme access points and a mix of some computers/servers connecting to VLAN 10. Their PVID is set to 10. The Employee VLAN is 10, so I can access all the APs they communicate fine with IPs on the PVID 10.
I have several SSIDs two that are used the most:
Wifi-Employee (trying to get working with 802.1x) (VLAN 10)10.10.0.0/16
The NPS server sits on port 5 of my switch and has an IP: 10.10.100.11
Wifi-Guest (works fine) (VLAN 40) 192.168.30.0/24
Hi @Patrick_M,
Thanks for the information. So, no matter the ethernet client or the WiFi client, if it tries to connect to employee VLAN 10, it needs to pass authentication, right?
Could you provide your firmware version and current configuration to me? I can help to check what might be wrong.
Zyxel Melen0 -
Clients connecting through ethernet on VLAN10 are fine, its the ones who are tyring authenticate through the NPS server.
Switch firmware: V4.70(ABMK.5) | 11/30/2021
Been searching for an update without any luck.
Hi @Patrick_M,
Layer 2 switch uses default management VLAN to send authentication packets.
Please help to change your Default Management IP from VLAN 1 to VLAN 10.
Zyxel Melen0 -
Thanks will give that a try. I am trying one different thing I found. I think I had to add all the options for authentication to my Network Policy. My initial tests last night were successful I will see today when users start using the wifi, but will also look at the management port.
Hi @Patrick_M,
Zyxel Melen0
- 601 USG FLEX H Series
- 480 News and Release
