Openvpn on armor g5
Hello Mehdi_13 @Mehdi_13
Welcome to the forum.
The user guide for Armor G5 available to download from https://www.zyxel.com/uk/en-gb/support/download and https://www.zyxel.com/uk/en-gb/products/wifi-router/ax6000-12-stream-multi-gigabit-wifi-6-router-armor-g5
has instructions about how to setup the Armor G5 as an Openvpn server or client.
Kind regards Tony
Hi and thank you for your reply, I have already read the user manual, but it does not talk about my problem, I followed all the steps, but the manual does not talk about the other three files, it is marked just add the openvpn.ovpn file , and so it doesn't work.
Hi friend, it's simple, I add my openvpn account, with username and password, and I add the openvpn.ovpn file provided by my vpn subscription, but it doesn't work
Hi @Mehdi_13 friend,
ok.
Do you have logging turned on, and is there anything in the logs to say anything about openvpn trying to set-up and about its failing please?
If logging is not enabled, could you enable it and try it again to see if any logs are available for you to share here?
Kind regards,
Tony
The log is activated, but when I want to read it, it asks me for a password that I don't know, is there a default password ?1 -
According to https://www.routeripaddress.com/routers/12398/zyxel-armor-g5.html the default password code be 1234
Hi friend,
You didn't understand me I think, when I download the Log of the Armor G5, it is compressed in .tar, I open it with 7zip, but it asks me for a password, I tried the password 1234 , but it does not work, there must be another special password to decompress the Log1 -
Hi my friend,
I know understand, but I don't what the password for the log tar file is.
@zyxel_jerry previously wrote the following to another user:
"You can private message the log .tar file to us by following steps below,
Click username which you want to sent the private message.
Click "Message", now, you can enter your message in the blank, and click "Post Message" to send it out"0
- 415 Beta Program
- 2.3K Nebula
- 141 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.5K Security
- 216 USG FLEX H Series
- 262 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 39 Wireless Ideas
- 6.3K Consumer Product
- 243 Service & License
- 382 News and Release
- 81 Security Advisories
- 27 Education Center
- 8 [Campaign] Zyxel Network Detective
- 3K FAQ
- 71 Security Highlight
