GS1915-8 Initial Firmware upgrade stuck
Stevens1
Stevens1 Posts: 1 image  Freshman Member
Yesterday I began installing my new switch, choosing to do the firmware upgrade. It is now the following day and the light on the switch is still blinking. How long should it take for the upgrade to be finished? What can I do to fix this since it is not even finished with its installation?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @Stevens1,
    Normally the firmware upgrade won't take too long.
    May I know if the SYS LED keeps blinking? If yes, could you help to press the restore button to factory default the switch and check whether the switch can boot up or not?
    Zyxel Melen
  • Zyxel_Melen
    edited July 2023
    Hi @Stevens1,
    Could you perhaps consider power cycling the switch by unplugging and then reconnecting the power cable? If the switch fails to boot up following this action, please proceed to submit the RMA request from this link.
    By the way, if you are going to submit an RMA request, please also send your serial number to me by private message.
    Zyxel Melen
