Issues with firmware upgrade GS2210
AndrewOx
AndrewOx Posts: 11
image  Freshman Member
Hello colleagues!
I'm having some issues upgrading my GS2210 switches to latest patch 4.50 (AASP 4).
So far on 3 switches(2x GS2210-8 and 1x GS2210-24) running 4.50 (AASP 2), when I'm trying to upload the new firmware file, the browser displays uploading percent, but the progress bar doesn't display. Also, the upload ends with "the switch didn't send any data "
I've tried a switch reboot, but without any success.
Has anyone encountered this error?
Thank you!
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,110
    image  Zyxel Employee
    Hi @AndrewOx,
    The Zyxel switch supports dual firmware images, image 1ras-0 and image 2ras-1. Please help to check which image is the current backup image and use the related command.
    Hope it helps.
    Zyxel Melen
