Warning 30006 and Error 30036
Reny2000
Reny2000 Posts: 1 image  Freshman Member
Hi, im trying to get the license sync but unfortunately i got before the warning "licenses are syinching now please wait, and now after 3 hrs the error 30036 cant connect to…..
How i can solve and got the license?
I add also Domain Zone Forwarder but without any success.
Thanks and regards
Renato
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hi Renato,
    error 30036 means Connect to myZyxe.com server has failed.
    Please check if the monitor log shows
    • myZyXEL.com GetTimeZone: Can not get correct feedback from server
    • myZyXEL.com Connection error has occured
    • myZyXEL.com GetTimeZone: Processing...
    If so, it could be DNS query fails, could you provide your Domain Zone Forwarder settings? thanks
  • Zyxel_James
    Hi Renato,
