Openvpn on armor g5
2»
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,376 image  Guru Member
    edited July 2023
    Hi @Mehdi_13
    To establish an OpenVPN tunnel with Armor G5, here is the example of using a mobile device. You can follow these steps:
    1.Set up a DDNS server for your Armor device and ensure that your WAN is assigned a public IP address.
    2.Enable the OpenVPN server feature on your Armor device.
    3.Once the OpenVPN server is enabled, create an OpenVPN account on the device.
    4.After creating the OpenVPN account, navigate back to the OpenVPN Server settings and export the configuration file.
    5.Save the exported file and add it to your OpenVPN app on your mobile device.
    By following these steps, you will be able to establish an OpenVPN tunnel with your Armor G5 device, allowing secure and private communication.
    Zyxel
    Untitled Image
  • Mehdi_13
    Mehdi_13 Posts: 10
    Hi and thank you for your reply,
    I already have a VPN subscription on Cyberghost, and I want it installed as a client on my Armor G5 not as a server, I followed all the steps, but it doesn't work, when I put my openvpn.ovpn file, my username and password, then I activate the openvpn, it does not work
  • Zyxel_Jerry
    Hi @Mehdi_13 ,
    The Armor G5 only support "OPENVPN" APP, we do not support other VPN APP.
    Zyxel
    Untitled Image
  • Mehdi_13
    Mehdi_13 Posts: 10
    Yes that's what I'm trying to do, if you read my question again, it's the Openvpn that I can't get to work, Armor G5 won't connect to my Openvpn account
  • Zyxel_Jerry
    Hi @Mehdi_13
    Here are the steps to set up open VPN settings on Armor G5 and how to export the vpn file to the client.
    1.Set up DDNS for your device and enable the OpenVPNServer.
    2.Create an OpenVPNAccount
    3. Go to OpebVPNServer page and click export config.
    4. Send the ovpn file to mobile and open the ovpn file using OPENVPN app
    5.Then Click Add
    Enable the connection.
    Zyxel
    Untitled Image
  • Mehdi_13
    Mehdi_13 Posts: 10
    Hi friend,
    I don't need the Openvpn server, I already have a VPN subscription, so I want to use my vpn on my Armor G5 as a client
  • RonLa
    RonLa Posts: 1
    i have the same issue when i try to set up openvpn client with my nordvpn credentials. it seems like it is impossible to add the ovpn file.
  • Zyxel_Jerry
    Hi @Mehdi_13
    The Armor OpenVPN client is capable of connecting to another Armor G5 device that is functioning as an OpenVPN server. However, if you are not utilizing the OpenVPN server feature provided by Armor or Multy M1, and instead using an ovpn file generated from Cyberghost, it is recommended to seek further assistance from Cyberghost for troubleshooting and support.
    Zyxel
    Untitled Image
  • Mehdi_13
    Mehdi_13 Posts: 10
    Ok, thank you very much, I will contact Cyberghost support
