firmware zyxel vmg 1312 B30B
Lubomir_
Hello,,
Where is possible download firmware to Zyxel VMG 1312 B30B?
Thanks for answer
Best regards
Hi there,
Not sure if you get the VMG1312 for your ISP or not.
If yes, you may need to check with the ISP.
Hi there,
Hello, This zyxel vmg 1312 B30B is for sale. I failed to upgrade the firmware, so I'm looking for the original firmware
- 601 USG FLEX H Series
- 480 News and Release
