VLAN tagged frame handling on the XGS1210-12
+1 encountering this ingress filtering issue as well. Need the firmware with ingress filtering release date.
Hi @eolo,
Thanks for asking.
I will give you an update about the ETA date.
Also, I will send the date code firmware to you via PM, please check the mail box.Zyxel Melen0 -
+1 i would need ingress filtering too :)
Would be nice to get an update.
BR
Chris
Hi @ChrisMini,
Welcome to the Zyxel Community!
I have sent the date code firmware to you via PM.
Please check your mailbox. Thanks.
Zyxel Melen0 -
The latest firmware includes the ingress VLAN filtering feature (VLAN ingress checking).
Please download it via this link.
Zyxel Melen0 -
Hi Melen,
Thanks for providing this, can you explain how this file / firmware is different to the version available under the official link here:
I've downloaded your file and the one from the below link and the files are different,:
File from User Zyxel_Melen:
Size: 6411077 bytes (6260 KiB)
SHA256: 259aac55b1a08c1847305084322edece9818449f5523bc1c91fd870052aaff7eFile from the Official link below:
Size: 6378757 bytes (6229 KiB)
SHA256: 4ff75d34efe068890587774464093cc1ca0fc6db376a141854763dfb77eb79760 -
Hi @saqib_s,
The difference is that the date code firmware adds ingress filtering by default. This is used to avoid receiving packets with the VLAN ID which does not belong to this port, and flood to that VLAN member ports.
Zyxel Melen0 -
So the file you've posted is the date code firmware. Will this feature be included in the a main branch upgrade in the future?
Hi @saqib_s,
Yes, this feature will be included in the next official firmware. I will inform you once it is released.
Zyxel Melen1
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
