Openvpn on armor g5
Hi @Mehdi_13
To establish an OpenVPN tunnel with Armor G5, here is the example of using a mobile device. You can follow these steps:1.Set up a DDNS server for your Armor device and ensure that your WAN is assigned a public IP address.
2.Enable the OpenVPN server feature on your Armor device.
3.Once the OpenVPN server is enabled, create an OpenVPN account on the device.
4.After creating the OpenVPN account, navigate back to the OpenVPN Server settings and export the configuration file.
5.Save the exported file and add it to your OpenVPN app on your mobile device.
By following these steps, you will be able to establish an OpenVPN tunnel with your Armor G5 device, allowing secure and private communication.
Zyxel
Hi and thank you for your reply,
I already have a VPN subscription on Cyberghost, and I want it installed as a client on my Armor G5 not as a server, I followed all the steps, but it doesn't work, when I put my openvpn.ovpn file, my username and password, then I activate the openvpn, it does not work0 -
Yes that's what I'm trying to do, if you read my question again, it's the Openvpn that I can't get to work, Armor G5 won't connect to my Openvpn account0 -
Hi @Mehdi_13
Here are the steps to set up open VPN settings on Armor G5 and how to export the vpn file to the client.
1.Set up DDNS for your device and enable the OpenVPNServer.
2.Create an OpenVPNAccount
3. Go to OpebVPNServer page and click export config.
4. Send the ovpn file to mobile and open the ovpn file using OPENVPN app5.Then Click Add
Enable the connection.
Zyxel
Hi friend,
I don't need the Openvpn server, I already have a VPN subscription, so I want to use my vpn on my Armor G5 as a client0 -
i have the same issue when i try to set up openvpn client with my nordvpn credentials. it seems like it is impossible to add the ovpn file.
Hi @Mehdi_13
The Armor OpenVPN client is capable of connecting to another Armor G5 device that is functioning as an OpenVPN server. However, if you are not utilizing the OpenVPN server feature provided by Armor or Multy M1, and instead using an ovpn file generated from Cyberghost, it is recommended to seek further assistance from Cyberghost for troubleshooting and support.Zyxel
Ok, thank you very much, I will contact Cyberghost support
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
