SecuExtender 4.0.3.0 (windows) not working (VPN connection still ok)
Hi @Thysmith,
AD user is able to establish SSL VPN to USG40.
Make sure ad-users is on the list of selected user in SSL VPN policy.
If you’re using the default Authentication Method rule, make sure “group ad” is on the list.
If you create another rule(ex: new_auth) in Authentication Method with “group ad”, remember to select the new created rule (ex: new_auth) in CONFIGURATION > System > WWW > Service Control > Authentication.
Hi Emily, Looks like my settings were correct and the Firmware update resolved my issue! Thank you so much!0
Hello:i have the same problem. Please, can you send me the latest version of firmware?Thank you!
Puoi inviare il new firmware SecuExtender v4.0.4.0 anche tramite DM? Grazie
Please find the SecuExtender on the Zyxel download library. The link is below:
Puoi trovare SecuExtender nella libreria di download di Zyxel. Il collegamento è qui sotto:Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
