Feature request: Fan control of XGS1250
Zyxel_Adam
Zyxel_Adam Posts: 429 image  Zyxel Employee
Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
edited July 2024 in Switch Ideas
User @Frantik85 proposes that
  • It's good to have an option/button to activate the fan.
Please help to give a vote if you also like this request.
Adam
4
4 votes
Completed · Last Updated
V2.00 patch 0 firmware supports this function. However, this function requires new hardware revision due to current hardware limitations.
  • MarkoN
    MarkoN Posts: 5 image  Freshman Member
    Please make it optional. Switch usually gets really hot and the fan is not even active. I would like to keep the fan always active.
  • tonynca
    tonynca Posts: 6 image  Freshman Member
    yeah I noticed mine getting pretty hot too. I would prefer to have it on as well.
  • robertogl
    robertogl Posts: 3 image  Freshman Member
    I assume this is a bit too late, but this feature would not only allow to control the fan, but it would also allow to test the fan.
    I had an xgs1250 with a 'broken fan' (it was never working) and I cannot test this on my new xgs1250 because there is no way to activate it.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    edited December 2023
    Hi @robertogl and all,
    Thank you for your inquiry about the XGS1250's fan functionality. I'd like to confirm that the fan is indeed temperature-controlled and activates only when reaching a predetermined temperature. We have thoroughly reviewed the possibility of enabling fan control through a firmware upgrade but, due to hardware limitations, found it unfeasible. Understanding the importance of this feature, we are excited to announce that we are working on releasing a new hardware revision that will include fan control capabilities.
    Zyxel Melen
  • robertogl
    Thanks for the update!
    A bit unfortunate that an hardware change is needed, as existing customer will not be able to use this…
