Maximum Sessions Per Host (1000) Exceeded
RGMConsulting
in Nebula
I am getting multiple "Maximum Sessions Per Host (1000) Exceeded" errors on my NSG50.
Hi, disable Session Limit or change the threshold.
Hi @RGMConsulting,
From your screenshot, client 10.9.1.59 created many UDP sessions with different IP addresses. Is it a server? If yes, you can go to Site-wide > Configure > Security gateway > Traffic shaping > Session Control to change the number of Session per Host.
If it is just a PC, you will need to check whether it is infected.
Zyxel Melen0
- 588 USG FLEX H Series
- 476 News and Release
