not enable to login
CMK
CMK Posts: 2 image  Freshman Member
After upload and apply new firmware runtime-GS1900-48HPv2-V2.70(ABTQ.5).bix into GS1900 8HP I'm not able to login admin/1234. I tried reboot switch manually, but the same result "The user name or password is incorrect." What I should to do to fix it?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,625 image  Zyxel Employee
    Hi @CMK,
    I tried to upgrade from 2.40 (AAHI.2) to 2.70 (AAHI.5) and login successfully. May I know what the original firmware version is?
    To fix this problem, you need to press the reset/restore button for 10 seconds to factory default it.
    Zyxel Melen
  • Zyxel_Melen
    Hi @CMK,
    Zyxel Melen
  • CMK
    Hi Melen,
    thank you, after reset login works.
