GS1910 Factory Reset no User/IP Management
i bought a second hand GS-1910 switch. The switch runs firmware 2.00.
I can access the webinterface with the brwoser and login with "admin" and "1234".
After I logged in the first time, there were no "IP" button in the system category. And no "User" butten in the Security → Switch category. In this category only the "RMON" button is visible.
I set back the switch to Factory Defaults with Putty, but the problem persits.
Did anyone have an comparable problem and can guide me to a solution?
I have to specify my problem:
It is not possible to make any changes to the webinterface. It seems the interface is in a "read only mode". Only the Maintenence part is working with reset and change the used firmware. But every other point in the menu is not showing any changeable setting.
Did you try this path Menu > Configuration to change settings?
- 221 Nebula Ideas
- 615 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
