How to allow anydesk through usg40 firewall
HI @Tushar
I suppose the log is: "abnormal TCP flag attack detected, Drop"This issue occurs when the device receives packets with:
(1) ALL TCP flags bit are set at same time.
(2) SYN, FIN bits are set at same time.
(3) SYN, RST bits are set at same time.
(4) FIN, RST bits are set at same time.
(5) Only FIN bit is set.
(6) Only PSH bit is set.
(7) Only URG bit is set.
Therefore, the device detects and regards these packets as attacks.
If you are sure these packets are safe, you can log into the device and enter the following CLI commands to disable this detection:
Router(config)# secure-policy abnormal_tcp_flag_detect deactivate
Regards0 -
Hi @Tushar,
With default configuration, Anydesk is not blocked by USG.
PC2 can access PC1 by Anydesk successfully without extra firewall or NAT settings.
PC2------Internet------(WAN)USG40(LAN)------PC1(Anydesk)
If there are lots of "abnormal TCP flag attack detected, DROP" logs, you can follow the instruction from Alfonso to enter the CLI command to disable/enable abnormal tcp flags detect.
Disable detect: secure-policy abnormal_tcp_flag_detect deactivate
Enable detect: secure-policy abnormal_tcp_flag_detect activate
For example:
Router(config)# write
Router(config)# show secure-policy status
secure-policy status: yes
secure-policy asymmetrical route status: no
secure-policy default rule: deny, log
secure-policy tcp flag detect: no
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
