Zyxel USG
Dpj
Dpj Posts: 209 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
i have an question about an issue we have many times. for our customers we use the Zyxel USG firewalls, and use SSL VPN connections.
Often when new firmwares are available, remote users cannot login anymore. Secuextender just doesn't sign in. For example this morning. i am running secuextender also on my laptop. i just can connect without any problem. the customer not. i use the same credentials, it just don't work. install firmware with offcourse reboot from the firewall solves the problem. This happens so often. it's quite frustrating. Costs us a lot of time. I hope someone can come up with a solution for this.
yours,
Dennis
  • Dpj
    sorry, i was very busy lately, i will check for specific characters in passwords. keep you updated
    PeterUK Posts: 4,366 image  Guru Member
    Re enter new credentials or even quick test with 1234 problem might be on upgrading firmware that special characters cause a problem.
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    What's your module ? USG1000 ?
    If so, I would suggest replace to then new one. It's so old and already end of support.
  • Dpj
